跳转到主内容
A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
How to replace the rear facing camera lens?
My sister's LG G3 rear facing camera lens broke and i have purchased a lens with adhesive from e-bay. My question is: how to completely remove the broken lens and what should i look for when i'm applying the adhesive and the new lens.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Wowza. You're real diy over there. Ok, so you'll want to use an xacto knife and carefully remove the lens. Go slow. Very slow. Clean the area. Gently scrape the ring around the hole. You could probably skimp on the % of isopropyl alcohol this time. Maybe you have some laying around? Be very careful, dab it on your jeans or something. Don't have the q tip dripping. Wait for that to dry, ten minutes is more than enough, then apply the new adhesive and lens, leave it back down so the camera lens is on the table, so it can adhere
这个答案有帮助吗?
得分 4
1条评论:
Thank you for your help.
完成的
添加一条评论
添加你的答案
Dávid Horváth 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 87
