跳转到主内容
Repair and support for the third generation of the Flip portable speaker by JBL.
The Charging PCB is destroyed. Any Solutions?
I know I shouldn't have, but when my JBL Flip 3's micro-usb charging port broke, I decided to take matters into my own hands. It's safe to say I destroyed the pcb that has the aux cord and charger. It's unusable. Is there anything I can use to replace this? I don't even need the aux cord, just the usb port. If i have to buy some cheapo charger pcb or make one myself, I'm down. It's a bummer to see this nice speaker end up in the junk drawer.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
6条评论
Hi,
Don't know your speaker but is the charge port on a separate pcb from the main amplifier board?
If so, does the charge port pcb have a 'board number' printed on it at all?
If so search online using just the number only and see if there are any results.
Just a thought.
完成的
It is a seperate pcb! but unfortunately I do not see any board number. Just a few markings like "C801" "j301" and "l205"
完成的
@ez2remember70 add some images of the broken board with your question. Use this guide 在已经存在的问题里加入图片 for that so we can see what you see.
完成的
Okay, Uploaded
完成的
I did the same thing. Did you ever find a replacement? I've been looking all over the internet and I havent found anything.
完成的
显示更多的1条评论
添加一条评论
2个答案
已选择的解决方案
Hello,
I had the same problem, just use the 4p cable for charging use the black - and red + for charging throug usb 5volt. You can solder a usb wire to it and it wil charge again! And then you can throw away that pcb!
Please let m know it worked for you too!?
Regards, Thiemo
这个答案有帮助吗?
得分 4
9条评论:
Hi,
I also wrecked the charging pcb and was about to throw away my JBL flip 3, then stumbled upon your comment and did exactly as you said. I now have a working and charging speaker with a usb wire permanently attached to it.
It has made me quite happy, thank you so much for your solution.
Best regards.
完成的
Hi ,
I have a same problem with my jbl flip2
And i suddenly noticed your comment here .
Thanks a lot
And can i use a normal 5 A usb charger to solder with the board?
完成的
Hello,
After soldering the USB cable to the speaker wires, I have plugged it in to a regular Samsung phone charger 5-9V and 1.64-2A I believe.
完成的
It worked perfectly. Thank you so much for this comment. Usb male type A red and black to the the 4pin’s red and black, I left the other wires disconnected. The speaker charges and is functional like normal.
This might be possible too: the leftover 3 pin could be salvaged to connect a female aux for audio input. Have yet to try it, maybe for a future DIY project.
完成的
Can anyone post a pic of the working solution please? The re-wire i mean :)
完成的
显示更多的4条评论
添加一条评论
Here is a post about howw to fix the problem https://openclassrooms.com/forum/sujet/r...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sabastian Watson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 43
总计 16,690
