跳转到主内容
加入维修社区 - 创建账户
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
F01 error code troubleshooting
Washer had been sounding terrible during draining. And the quit running during random intervals during a cycle. Mostly right after the wash cycle. Cleaned filter, no success. Replaced the drain pump assuming it was the issue, had that problem before. Nope. Also changed the door lock switch thinking it was the safety mechanism preventing a spin cycle. Nope. Finally ran the diagnostic and figured out the F01 code. Checked my ccu for bulging capacitors or burnt out solder point. It looks good to me (though I'm not s professional). Any ideas before I go dropping money on a new ccu? I read somewhere I might have a timer issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@dgadoci, Drew , Before dropping money on a new CCU, Unplug machine and go over all connections, unplugging connectors checking for corrosion/burn/damage/loose wires, clean if required and reconnect making sure connection secure/tight. Service manual below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Duet-Aid_also-Kenmore-HE3.pdf
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Drew 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 4
总计 1,060
