跳转到主内容
Repair guides and support for the popular 3rd generation VW Jetta. Sold in Europe as the VW Vento.
13 个问题 查看全部
Why does my Jetta not shift into 2nd or 4th gear but fine on 1st, 3rd,
Myh 92 Jetta 5 speed manual wont shift into 2nd or 4th gear. If rev'd up, will go into 3rd and up to 5th. What could this problem be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Spray the linkages. I had a problem similar but wouldn't go in reverse.
完成的
添加一条评论
3个答案
已选择的解决方案
catherine.a.elliott73 , There is a possibility that the shift linkage bushings or cable brackets are bad/loose or it could be a more serious transmission internal issue like worn/bad syncro's/gears/bearings, damaged/bent shift fork,etc.. Have a good local transmission shop have a look, diagnose and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
得分 2
添加一条评论
There are several reason but the most likely issue will be with the syncros in the gear box . It could also be the shift linkage has been damaged or bent and therefore will not move freely . The fact that you can get it to shift if you power shift suggests that the problem is with the syncros
这个答案有帮助吗?
得分 1
添加一条评论
Mine does the thing, I replaced all the linkages - that didn't solve it.
I then replaced the gear box and it's still doing the same thing.
Somebody please
这个答案有帮助吗?
得分 0
1条评论:
The only thing left to fix is the gear shifter and its bushings, WOW. Your linkages may be out of adjustment.
完成的
添加一条评论
添加你的答案
catherine.a.elliott73 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 9
过去 30 天: 31
总计 7,110
