Phone ded due to a water
My phone is not getting on. but when I connected to computer in the devices and printers window it shoes as android device. And in Device manager it shows Sony storage device. please help me to slove this problem.
Thanks
Hi,
As you now know, water and electronics and electricity are not a good mix.
The minerals in the water cause corrosion and the water also provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion process starts immediately and will not stop until it has been thoroughly cleaned away
First do not turn on your phone and then you need to with the phone turned off, remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% or less and is not as effective. If you do check the label to verify the amount
Here is a link that describes the process.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 425
2条评论
The good news is that your phone is showing in your computer, so it isn't completely dead.
Can you hear any sounds coming from the phone? Does a charging LED come on?
由 martywild10 完成的
dear friend,
Thanks for your quick response and kindness. When I connected the charger charging led getting on with red color and few moment it turned to green color . I can't hear any sounds but when I press hard reset butten I can sense two vibrations.
thanks
由 Kushlan 完成的
