跳转到主内容
加入维修社区 - 创建账户
GoPro Hero5 Black是GoPro于2016年10月发布的高清防水运动相机。具有4k分辨率录制和语音控制,触摸屏显示和内置WiFi功能。
Camera will not power on without cable plugged in (full battery too)
I dropped my go pro off a coffee table onto a tile floor while it was recording and fell at most 2 feet, it shut off and wouldn't power back on. I tried new batteries (all which work on my other GoPro Hero 5) and would not power on.
It does power on when I have it plugged in with the USB cord, but turns off immediately after I unplug it.
I'm not particularly tech savvy but I assume the drop knocked something loose in the battery housing?
Any help would be greatly appreciated. It's about 2 weeks old so it's a little frustrating.
Thanks,
Lee
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Thanks for the suggestion. I think that's above what I'm comfortable with regarding at home repair. Do you know if I can just mail the camera into GoPro for repairs or would you suggest going to a local shop/Best Buy?
Thanks,
完成的
You certainly should be able to send it in for a repair, but you need to contact GoPro for that process, there may be a fee or you may still be in warranty, but do call them and find out your options.
完成的
添加一条评论
1个答案
已选择的解决方案
Sounds like the pins for the connector may be damaged or not connecting properly with the battery, honestly the only fix is a teardown and double checking the pins. Although I suppose you can check with a multimeter while the power cable is plugged in and touch the appropriate pins to see if the pins are allowing current to flow, if not then you may need to re-solder the pins onto the board.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
curranslee10 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 32
总计 1,253
