跳转到主内容
Eighth generation of the Mazda Protege.
20 个问题 查看全部
What wring when handbreak will not turn off while driving?
Why does the handbrake not turn off even while driving?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@denzy53 , Denise, Do not drive your car if you suspect the hand/E-brake is on, as the rear brake cylinders could potentially heat up and leak the brake fluid out, leaving vehicle with very little or no braking. The Park brake cables could be seized, retracting springs broken,etc. not allowing hand brake to release fully, also is possible if it is just the park brake light is on that the switch could be faulty or may need adjusted. For your safety have the problem checked, diagnosed sooner then later, by a good local reputable shop and estimate for repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Denise 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 89
