跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone 6 shows 4G but no cellular data
I've got an iPhone 6 that shows 4G up top but will not connect to cellular data. Phone calls can be made, but cannot access the internet. If connected to wifi, internet can be accessed.
Background info:
Screen replacement previously done on this phone. Phone has been working fine for few months. This issue occurred right around the same time that plan was changed with ATT. The phone used to show LTE but now shows 4G up top. AT&T says it is nothing on their end.
Any ideas??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
4条评论
I had this problem too and tried to reset the network settings, unfortunately that did not help. When I tried finding the network status I stumbled upon my vpn configuration trying to connect. When I turned it off my internet connection worked again. So that might be worth looking into too.
完成的
Same problem, same cause and fix!
完成的
Thank you so much for the initial question and the solution. After so many attempts at trying to figure out the multitude of possibilities of what the issue was, turning off my VPN was the problem!! Thank you!!
完成的
For reference: I have an iPhone XR, Mint phone service, Express VPN
完成的
添加一条评论
8个答案
已选择的解决方案
Sounds like a provisioning problem. Go to Settings > General > Reset > tap "Reset Network Settings". The phone will automatically restart. Let me know if this solves your issue.
这个答案有帮助吗?
得分 6
10条评论:
Unfortunately that did not work. Any other ideas?
完成的
What does it say on Settings > General > Network Status? Hopefully not 'Phone not allowed.' Have you tried another sim card to test cellular data from sim?
完成的
I'm fairly certain it's the SIM card then. If AT&T is confident they have entered the correct information ,and resetting network settings did not work... Try a different SIM card or purchase a new one.
完成的
Ben, I do not show a "network status" under settings > general
完成的
Christopher, SIM has been replaced by ATT since problem started to occur.
完成的
显示更多的5条评论
添加一条评论
I recently had a trip to Japan for which I switched my sims so I didn't get charged for using my phone abroad. When I returned to the US, I switched my sims back and I started to have this issue. While I was troubleshooting with the general settings I noticed that the Japanese sim had created a configuration profile for me. Once I deleted it everything went back to normal.
Its missing on my phone now, but it should be under: Settings>General>Configuration Profile>Delete Profile
Other Instructions to delete configuration profile from apple are in the link below:
https://support.apple.com/en-us/HT205347
Hope this helps!
这个答案有帮助吗?
得分 5
3条评论:
I have had the exact problem until now. I just returned from Israel in which I replaced the sim card with a local carrier and automatically it created its own profile. I removed the profile per Michael's advise and sure enough, problem solved. Thanks a lot for the information.
完成的
Solved my problem like nothing else had! Thanks a lot!
完成的
Can you help me my iPhone network not show
完成的
添加一条评论
I just had a similar issue with my iPhone 6, searching and no service most of the time and if I get a signal eventually it only shows 3G (it should be 4G) and there is no data coming trough (works fine on WiFi). What I did is I replaced QFE1100 (the signal power ic) which was corroded due to water damage and now my phone works fine, I have 4G and I have SIM data. Hope this helps someone :)
这个答案有帮助吗?
得分 1
添加一条评论
im having this exact same problem with a 6 plus! if you find out whats wrong with it let me know please!
这个答案有帮助吗?
得分 1
1条评论:
It ended up being that ATT did not have the IMEI on their end correct. Doh!
完成的
添加一条评论
I m also facing similar- ditto issue, my phone works only when i switch off and re switch on again. As i notice, this mainly happens when I connect to one WIFI ...when I come out od wifi there are no more wifi signals and mobile data fails to pick up.
Plus, my wifi mobile data switches ON itself automatically.
this might be another Apple upgrade issue.
Pl help. My network says no error on their behalf. Plus my sim a'int old enough.
I dunno.
这个答案有帮助吗?
得分 0
添加一条评论
I also have a similar problem. I can see the LTE sign on top, but i have no internet. However, the only app that can access the internet, is the safari. My phone works fine with WiFi. This problem started very sudden. I have tried reseting the device. I have also reseted the network settings. But still the same problem. Any suggestions?
这个答案有帮助吗?
得分 0
添加一条评论
What a great advise to remove the extra profile that will definitely solved your network issue. Thx
这个答案有帮助吗?
得分 0
1条评论:
I’m having the same problem with my iOS 12 developer bets on Verizon iPhone X running simple mobile!!!!
Shows Lte still nothing.
Checking IMEI shows clean,settings/general/about phone shows the phone active and allowed so I don’t think it’s anything other than either A. Software problem B. Network problem meaning on the carrier end.
I will repost results ASAP.
完成的
添加一条评论
Hi guys, I have similar problem. My cellular data works for some time and then randomly stops working for a few minutes. Then it works again. The signal is shown as normal and calling works normally. It’s just that the internet has speed of 0 mbit/s, nothing loads. My iPhone is 6s Plus.
I thought it’s the operator, but I experienced the same thing abroad with another SIM card. I tried reinstalling iOS and resetting network settings.
Is there something I can do?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
devansmain 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 37
过去 30 天: 144
总计 113,094
