iPhone 6 shows 4G but no cellular data
I've got an iPhone 6 that shows 4G up top but will not connect to cellular data. Phone calls can be made, but cannot access the internet. If connected to wifi, internet can be accessed.
Background info:
Screen replacement previously done on this phone. Phone has been working fine for few months. This issue occurred right around the same time that plan was changed with ATT. The phone used to show LTE but now shows 4G up top. AT&T says it is nothing on their end.
Any ideas??
4条评论
I had this problem too and tried to reset the network settings, unfortunately that did not help. When I tried finding the network status I stumbled upon my vpn configuration trying to connect. When I turned it off my internet connection worked again. So that might be worth looking into too.
由 Marysca Moïzede Chateleux 完成的
Same problem, same cause and fix!
由 Ian Swinton 完成的
Thank you so much for the initial question and the solution. After so many attempts at trying to figure out the multitude of possibilities of what the issue was, turning off my VPN was the problem!! Thank you!!
由 140gal 完成的
For reference: I have an iPhone XR, Mint phone service, Express VPN
由 140gal 完成的
