跳转到主内容
Announced on July 2015, this is Motorola's flagship phone. It has a 21 mega pixel camera with a 5.7 inch IPS TFT LCD screen with a resolution of 1440 x 2560 making it Quad HD. Model number XT1570, XT1579, XT1575 and XT1578.
61 个问题 查看全部
Power Button Not working after screen replacement
I recently changed the screen on 2 Motorola Moto X pure edition, Because it was cracked but after replacement the power button doesn't work anymore. I wonder if that could be a defect on the screen I bought. Or if I did something wrong. I followed a online guide changing everything. And Both screen bought from the same seller won't power on. It does light up when I charge just not able to tun it on. what do I have to do ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Did you ever figure this out or solve it?
完成的
添加一条评论
3个答案
已选择的解决方案
I had the same problem - my power and volume buttons stopped working after replacing the battery.
Refer to step 8 here, specifically the 2nd screenshot (2 of 3). I had to reseat my power/volume flex - I did not have to reseat the connector to the board.
The 2nd screenshot shows a cable that could have come loose. Mine was glued down and taped, but had still come loose (probably while heating the phone up to take the back plate off).
I used long thin pliers to peal the clear tape, reseat the flex, and put the tape back on again. The phone works great now!
这个答案有帮助吗?
得分 2
1条评论:
Same problem and same resolution, but with Moto Z Force Edition. Thanks!
完成的
添加一条评论
there is a small rubber cover on the upper left hand side of the back plate after you close the phone back up. If you remove the cover it exposes a ribbon cable and connector the you can push to connect back to the main board. There is another one near the bottom for the same purpose to connect the battery.
I found and reconnected the one near the bottom but I missed the connector in the top left. The phone exhibited similar behavior: screen lights up when plugged in but power button doesn't respond. Hopefully that is also your issue. Hope that helps.
Connector locations
这个答案有帮助吗?
得分 1
添加一条评论
I have same problem,after screen replacement, but i dont know where is this place. Where is 2 from 3 screen? Please help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
matheusphillipemuniz 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 53
总计 3,802
