跳转到主内容
Device repair and troubleshooting for the 7" RCA tablet released in 2014, identified by model number RCT6773W22.
129 个问题 查看全部
The sound is gone
The sound is gone can't figure out how to get it back
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
2条评论
Hi,
Do you have audio when using the earphones?
完成的
Yes
But I need sound so I don't have to use earphones
完成的
添加一条评论
1个答案
已选择的解决方案
First try headphones. If there is sound, likely the speaker, speaker connection, or logic board has issues.
If there is no sound on the headphone,
Reboot your tablet into recovery mode, as follows:
• Hold 'vol down' and 'power' buttons on tablet
• Release 'power' when samsung image is shown
• Release 'vol down' when the two icons are shown
• Use the 'vol down' to navigate between the icons
• Highlight the left icon (box)
• Press the 'vol up' to select it and boot into recovery mode
In Recovery mode, 'vol up' and 'vol down' move up and down in the menu, and 'power' button selects.
First try the 'wipe cache partition' and reboot.
If this doesn't help, follow the instructions above then use the 'factory reset' option instead. (REMEMBER TO BACK UP FIRST!!!)
If this doesn't help, there likely is a problem with your logic board.
这个答案有帮助吗?
得分 3
4条评论:
S W.... thank you so much for answering my question about my sound couple things one it's an RCA not a Samsung so is it still going to work the same into how do I back it up
完成的
Androids all have a similar 'Recovery Mode'. Backing it up either can be done in Settings-->Backup&Reset and you can backup critical data to Google, or if RCA has a PC utility to backup to a PC, you can use that. I would manually connect to a pc and copy photos and other critical files over to a PC by drag and drop for anything important just in case.
完成的
Most helpful, I have another issue; already tried, the ones recommended. need to know how much it’ii cost to repair.
完成的
@Carmen Morris
What is the "other issue" with the tablet?
This will help to give advice on what may be required to fix the problem and therefore how much it may cost
完成的
添加一条评论
添加你的答案
ks.eastburn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 3,453
