跳转到主内容
加入维修社区 - 创建账户
The Xbox One Wireless Controller model 1697 was released in 2015 and replaced the model 1537 controller and fixed some of the problems found on Model 1537 controllers. The Model 1697 controller includes an integrated 3.5mm headset jack, which allows compatibility with most 3rd party headsets without the need of an adapter. This controller has been discontinued and replaced by the Model 1708 controller.
Defective Xbox One Controller?
My Xbox One Controller will not turn on. I have tried very simple answers like changing the batteries, but it still won't turn on. I don't recharge old batteries or anything of the sort. It just won't turn on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
What occured before this happened? Any liquid damage? Did you get this new or used? How long have you owned it?
完成的
添加一条评论
1个答案
Check the solder points
这个答案有帮助吗?
得分 0
7条评论:
What solder points? Where? How do i open the controller?
完成的
Why are you following me wherever I answer? This isn't your question
完成的
Because yoru answers aren't very good. Im sure @mayer can back me up on this. Your also not being polite
完成的
Cameron. Why not just answer the question correctly, give a link on how to identify and repair cold solder joints. Also advise on how to diagnose. He does answer a lot of questions poorly and incompletely. Remind you of someone that did the same thing when they started?
完成的
@mayer Yes. But also im trying to help him like you helped me.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Spencer Rinder 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 283
