跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2265 个问题 查看全部
I broke the home button to iPhone 7 internally
I am replacing an iPhone 7 screen and have not done one of those yet. There is another cord on the side of the phone that I did not see which is the home button. I didn't see if. And I broke it. Do u know where to find that piece?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
If it's the cable that directly comes and is connected to the home button itself then you can't just replace it as it will not function at all.
Apple is the only way at the moment to get the home button to work again (They will probably charge you a screen replacement).
这个答案有帮助吗?
得分 2
添加一条评论
If you broke any part of the home button, you must take it to Apple in order for you to have Touch ID and physical home button functionality back. The home button is "married" to the logic board, therefore there is no way to replace the button and expect to have any functionality.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Emily 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 113
