跳转到主内容
The Asus Q502LA is a convertible 2-in-1 laptop that combines versatility with performance, making it ideal for students, professionals, and casual users.
How can I remove the keyboard to clean underneath?
I left my Asus Q502la open while i was at work one day and my kid got crumbs all over the keyboard. How can i access underneath the keyboard to make sure its clean? I can get the bottom cover off but Im not sure where to go from there. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
You have 2 options as the keyboard isnt easily removable.
One is to remove the key caps and and clean underneath them.
Two is to use compressed air to clean underneath the keys.
If 2 doesnt work 1 is the way to go.
WHEN REMOVING THE CAPS, BE CAREFUL NOT TO APPLY TOO MUCH PRESSURE AS YOU WILL BREAK EITHER THE CAP OR THE MECHANISM INSIDE!
Hope this helps as this was the 4th or 5th time of me writing this. If it did please hit the accept answer button!
这个答案有帮助吗?
得分 2
1条评论:
This guide might be of use if you need to remove any keys: https://www.replacementlaptopkeys.com/as...
完成的
添加一条评论
I would recommend you to give your laptop to a near by computer store they will open the laptop for you.
If you want to do it yourself-
Remove all the screws you can see. Disk drive , ram vent etc.
Make sure to remove battery and disconnect adapter. There is space between upper plastic(covering mobo) and area below it. find it and use a thin screwdriver to open it. carefully clean it. the removing process is very dangerous that's why going to a store is recommended .
这个答案有帮助吗?
得分 -1
1条评论:
It actually isnt very dangerous. Ive taken apart countless computers with no issues. A dissasembly video would be nice. Also if you did ANY research, you would know that there is no "seam" between the 2 halves as this was put into another material and the keyboard is not easily removed.
完成的
添加一条评论
添加你的答案
Ryan Scott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 1,146
