跳转到主内容
The second generation of the Ford Ranger, featuring a mild restyling and new engine sizing.
41 个问题 查看全部
How can I stop oil from leaking from the spark plug hole?
My 1993 Ford Ranger uses 2 quarts of oil a week. I changed the spark plugs and one had oil all over and inside the hole where the plug screws in.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
my spark plug had oil but are too much ,is that normal found plug like that?
完成的
添加一条评论
2个答案
最有帮助的答案
I bought a couple of spark plug oil seal from 4WheelOnline and a couple of truck accessories. I did the repair by myself. Its a 1-hour job.
这个答案有帮助吗?
得分 2
添加一条评论
Change out the tappet cover gasket, unless they are in the side of your head. If that is the case then it is most likely that your plugs are fouling with oil due to either worn rings or leaky valve stem seals.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
tinalougarrison 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 1,289
