跳转到主内容
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Digitizer cable connector stucked in the logic board socket
Hi,
I did get digitiser replacement. I connected digitiser cable connector to the socket. Suddenly, cable went off but cable connector stayed in the socket on the logic board. Any idea how to remove it safely please?
Update (05/03/2017)
Hi guys,
Thanks for your advice. As you can see, English is not my first language. I try to modify my question and add pictures..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I'm a bit miffed, and it appears no one else answered this. So you removed the plate, and attached the new connector cable? And it broke off? If that's the case, scoop, don't pry, the new connector cable off the socket, then return it. There's something wrong with that cable, if it's breaking like that. Get it exchanged for a good one. Don't take no for an answer!
这个答案有帮助吗?
得分 1
1条评论:
was writing my answer just as you posted yours ;) I didn't think of the hows and whys though...
完成的
添加一条评论
You can try heating it up gently with a hair drier..possibly the heat will cause some metal expansion that will make it easier to remove. In any case a moderate heat will provide a slightly better flexibility and help prevent breaking of parts.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bretislav Kaluzik 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 98
