跳转到主内容
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
My right bumper is not working when I press it.
The right bumper on my Xbox One controller is no longer working unless I press it a bunch and then it will MAYBE click. I need help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
5条评论
Is it sticking or simply unresponsive?
完成的
yes it wont do anything and I mainly use my right bumber for almost every game
完成的
I have three controllers now and it’s !#^&^$^ me off, The first one just stopped working, the next one was working fine, until it was a bit unresponsive, but then it stopped working completely
完成的
I also have 3 with r bumper failure...one is now 3months old, that new ghost controller...top half is see thru...I can see it working just fine, all 3 controllers click just fine...its very frustrating
完成的
My rt won't work I keep pushing it I get no response.
完成的
添加一条评论
7个答案
已选择的解决方案
I had this happen before, it was the detent had broken.
If that's the case, I would but one off ebay and save the broken one for parts.
这个答案有帮助吗?
得分 2
1条评论:
I can’t find one it’s not on amazon either, are there any other places
完成的
添加一条评论
最有帮助的答案
If you press down the right trigger and blow into the the right bumper in the gap may 10 times then it somehow fixes it.
这个答案有帮助吗?
得分 4
4条评论:
Unfortunately that does not work at all on it, tried that when it was suggested a long time ago.
完成的
This fixed mine, thanks.
完成的
This surprisingly fixed my problem. Thank you, you were god sent
完成的
quite surprised this worked
完成的
添加一条评论
I had that happen, took the controller apart and found the bumpers were still intact. I think what happened was the metal bracket that holds the button in had become bent. What I did was apply a layer of super glue along the part of the bumper that makes contact with the button to give it a bit more length so it can fully press the button
这个答案有帮助吗?
得分 2
3条评论:
tried some similar thing, now superglue is stuck inside the button on the board, fml
完成的
@asimdaud how did you do that
完成的
I don’t remember what I did 5 years ago to fix it but with super glue you have to be careful as it messed up the button
完成的
添加一条评论
a couple months ago I had bought an Xbox elite series 2 remote for my birthday and was acting just fine. A couple weeks later my left bumper has become completely unresponsive when I press down on it. Anyone know how to fix this? I really don’t want to spend out on a new remote when the rest of it is perfectly fine :(
这个答案有帮助吗?
得分 2
3条评论:
Try holding the bumper down and then blow into it. That may work it worked for me.
完成的
It also fixed mine
完成的
and it fixed mine to
完成的
添加一条评论
you. have to restart consle wait 5 seconD's and it wrks
这个答案有帮助吗?
得分 1
1条评论:
Unfortunately, this one just does not work.
完成的
添加一条评论
im tired of dealing with this i might honestly just buy a new controller
这个答案有帮助吗?
得分 0
添加一条评论
i just blow into mine, still acts up from time to time. Also check for gunk in between the bumper and trigger, if there is any, clean it out with a tooth pick or pencil
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Thorusofer Dragon Knight 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 29
过去 30 天: 133
总计 71,802
