跳转到主内容
The Apple TV is a digital media receiver designed by Apple and released on March 21, 2007
Why have they all started jumping?
I have 3 Apple TV 1st generations and they have all developed exactly the same fault at the same time. Coincidence? They no longer play saved content (films) without constant pausing and. Jumping. Has anyone else experienced this issue and - if so - what's the fix? I have tried a factory restore on one, but no ch age.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Are you connecting to the same TV? Are these devices hacked (like Kodi or jailbroken)?
完成的
Hi, they are attached to different TVs (the same ones that they have each been attached to for ages) and have not been hacked.
完成的
添加一条评论
1个答案
已选择的解决方案
Check your local connection (Ethernet or WiFi) internet connection if you are streaming as that maybe the real issue.
If you live in a dense area its likely someone is stepping on your WiFi band if you are using WiFi to connect the Apple TV to your Internet Router. If you are using wired Ethernet connection then it could be an ISP issue.
If you have a Mac give this app a try: WiFi Explorer it will allow you to see the bands that you and the others around you are using.
这个答案有帮助吗?
得分 2
14条评论:
Thanks,but would that affect the playing of movies saved onto the Apple TV 1st generations own hard drive?
完成的
No, But to be sure I would disconnect the network connection (Ethernet or WiFi) as their maybe some other process running in background which is having an issue.
完成的
I also need help for this
Same as what @ispl said
"playing videos on the apple tv hard drive"
Please help
完成的
@beanman56 - The drive maybe failing or highly fragmented so the movie is to badly scattered across the platters.
完成的
Ok thanks for the help,
Also @danj do know what format it takes for external drives?
完成的
显示更多的9条评论
添加一条评论
添加你的答案
pipbaldwin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 22
总计 396
