跳转到主内容
修复你的物品
维修的权力
配件 & 工具
GPS unit with 4.3" screen.
9 个问题 查看全部
My unit will not find chicago, illinois
I am going to go to Chicago and when I put the address in it says it does not find it? Whats up? Do I need to update?
Thank you!
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
1个回答
已选择的解决方案
This is what I would try:
• Download and install Garmin Express on a computer
http://software.garmin.com/en-US/express...
• Connect your Nuvi to it. Make sure all updates have been downloaded and installed.
• Gamin may have a couple options where you were able to select which state maps were loaded on your system. If Illinois was not loaded, make sure it is.
• If there is no such option, there is another option in Garmin Express that lets you download a complete fresh updated copy of your maps.
Hopefully then you will be able to search the address you need.
这个答案有帮助吗?
得分 2
评论:
Thank you! That worked!!
完成的
添加一条评论
添加你的答案
Nancy Howard 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 68
