跳转到主内容
The Sony Extra Bass Headphones Model: MDR-XB450AP, are a high end pair of headphones that are manufactured by Sony. Features an omni-directional microphone for Bluetooth capabilities.
19 个问题 查看全部
Sound is low and faint
I have just been given a set of Sony headphones model number MDR-XB450AP. When plug them into my computer and my iPod touch they work fine but when I plug the extension cable that I have the volume on headphone is low and faint. I know the extension cable work alright with other heads.
Update (05/02/2017)
Here are the photos that you wanted. Photo 1 is of the Sony headphones. Photo 2 is of the Sony headphone plug. Photo 3 is of the other headphones that work. Photo 4 is of the plug from the other headphones that work. Photo 5 and 6 is of the extension cable.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
5条评论
Hi,
Just wondering, is there sound in both the left and the right headphone?
Also do the other headphones that you tried with the extension cable have a 4 'ring' connector plug like the Sony, i.e. TRRS plug (tip, ring 1, ring 2, sleeve) or a 3 ring TRS plug (tip, ring, sleeve)?
If not the extension cable may not be suited to a TRRS plug (it should be but....)
http://www.cablechick.com.au/blog/unders...
完成的
There is sound in both the left and the right side of headphones. The other headphones I have tried I am not sure but I think they either have a 1 or 2 ring.
完成的
Hi,
Post some close up images of:
1 the plug from the Sony headphone.
2. the plug from one of the headphones that work with the extension cable.
3.the plug from the extension cable.
Here's how to do it 在已经存在的问题里加入图片
完成的
@jayeff looks like you are on the right track ;-)
完成的
Thanks for that help
完成的
添加一条评论
2个答案
已选择的解决方案
Hi,
Your problem is that the "ground" connector" in the "female" socket of the extension cable is contacting the "microphone" connector in the Sony "male" plug and not the ground connector.
If you get one of these adapters to connect between the Sony headphones and the extension cable, it will solve the problem.
There are two main "wiring standards CTIA & OMTP" and depending on which particular one you have (and you might not know until you try it) and what you are trying to connect it to, this adapter will allow it to work for either one, unless you don't need it at all.
You do not have to buy a new cable.
Update (05/04/2017)
Hi Angela Cameron,
Just search for a 3.5mm 4-Pole TRRS Standards Bi-Directional Adapter and select the supplier of your choice.
这个答案有帮助吗?
得分 3
6条评论:
Thanks for everything. Do you know where I can buy online a 5m extension cable for headphones that doesn't cost a lot of money. It can be long than 5m but no shorter
完成的
So when I go to search for this on the internet what do I put in the search to find this
完成的
I am still waiting for an answer to the question I last asked
完成的
Hi Angela,
I posted the answer you wanted the day after you asked it on the 05/03/2017. It is shown under "Update (05/04/2017)" in the Most Helpful answer above.
It was placed there so you and others would not have to search through all the subsequent answers (if any, and any other questions which are in the answer boxes) to find it.
完成的
My sony headphones MDR-XB450 wired have problem the sound is there but vocals are only just recognisable any help would be great thanks
完成的
显示更多的1条评论
添加一条评论
Extension and Sony headphone not compatible. Simple terms, extension has 2 line on pin, heads have 3. So when you plug extension to port, you are only getting 2/3 of sound. Buy ext with 3 pins.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
angela cameron 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 16
总计 6,397
