need new charger or tablet is bad
Charger is not charging would like to order a replacement.
bobbieann, Posted a couple links below for 2 different RCA 10 Viking Pro models, make sure part is correct for your model# prior to placing order. You can also do a search yourself for better pricing perhaps. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
1st link below replacement charger is for model RCA 10 Viking Pro (RCT6303W87DK) 10.1
2nd link below replacement charger is for model RCA RCT6103W46 PRO 10, 10 inch Tablet PC, AC Wall Adapter Cable Charger
这个答案有帮助吗?
bobbieann , did these links for charger work for you?
will w87dk work it should be w87m7 i ordered wrong one pleeez answer
THE complete model no. is RCT6303W87M7 BUT I ORDERED RCT6303W87DK INSTEAD WILL IT STILL WORK
Sandra Carter, It appears the end on the charger for RCT6303W87M7 is a pin style and the RCT6303W87DK takes a micro USB charge port, so unless charger were to come with special adapters it will not work. Best to cancel order and reorder for proper cable.
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 606
1条评论
pleez help me i ordered rct6303w87 dk charger to my rca viking pro 10 tablet it should be rct6603w87m7 will it still work
由 Sandra Carter 完成的
