跳转到主内容
加入维修社区 - 创建账户
The K-Gro PowerPro is a ridable lawnmower built for K-Mart by MTD and Murray. Released in 1997. Model numbers: 13AL452F120 (38", 12 HP) & 13AQ695H120 (46", 18 HP).
deck belt won't engage blades
Took the deck off my 38" 12hp PowerPro so I could sharpen the blades. When I put deck back on, the belt won't engage the blades...too much slack. Is there an adjustment for this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
You are correct L Pfaff, this is a very simple belt routing and I had it right. My guess is that the belt is stretched; going to order a new one. Thanks for the answer!
完成的
@donovanb,Donovan, Thanks for replying back, wish you good luck with your mower.
完成的
添加一条评论
1个答案
已选择的解决方案
Donovan B, I looked through the manual and does not show any adjustment for the deck belt and I assume you have belt routing correct(links below have routing) as looks pretty easy compared to some, maybe recheck your deck installation, springs/arms/etc.. I new belt, either you were given the incorrect belt size MTD 954-0329A V-BELT .625X69.28, or that the pulley's may be badly worn or old belt stretched.
I posted links below to show the belt routing, correct belt# and the various spring positions. The 2nd link is where you can down load your owners guide/manual. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.jackssmallengines.com/jacks-...
http://www.mtdparts.com/equipment/mtdpar...
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Donovan B 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 1,411
