跳转到主内容
Repair guides and information for bread makers.
20 个问题 查看全部
Everything works but the paddle doesn't turn and has no engine noise
Everything works but the paddle doesn't turn and has no engine noise. It heats and lights up.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I have a Chef Mate bread machine its probably 10 years old not used much (about 20 loaves) til now. The machine lights up but the motor doesn’t turn on and therefore the paddle doesn’t turn. Need to get a referral for a repair shop in the vicinity of Spokane Washington telephone #
完成的
添加一条评论
1个答案
已选择的解决方案
melwoodonly, If still under warranty use it to have bread maker repaired/replaced/refund. You did not state your make/model#, so I will post some what generic answer. The motor may be faulty, or internal wire/plug may be loose/broke/burnt, limit switch if equipped faulty, bad control board, etc..You will have to disassemble the bread maker so you can do a visual inspection for loose components and test the motor etc.. If not wanting to do the repair your self take into a good local small appliance repair shop and have them take a look and estimate repair. Link below is just an example of how to disassemble a bread maker, which you may be able to search for using your make/model#. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Hitachi HB-B102 Automatic Home Bakery II Motor Replacement
这个答案有帮助吗?
得分 1
1条评论:
Have a Hitachi HB 201...Motor doesn't turn, but the display goes through the other phases and the fan comes on. Could the 8mf motor capacitor be bad...how do I test it?
完成的
添加一条评论
添加你的答案
melwoodonly 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 31
过去 30 天: 92
总计 2,520
