How to replace the usd charging port?
Is it possible to change the charging port and if so, is there an easy to follow tutorial?
It appears that the port is soldered to the board, along with the fact that disassembling the controller in the first place it difficult and an all in procedure. So there is absolutely no easy way to do it. I'm sure that it can in fact be done, but I think you would be better off buying another controller just because the fact that this procedure is so difficult.
Here is a teardown guide if you want to try...
这个答案有帮助吗?
hi. thanks for your input. after a little trial and error I have cracked it and it is easier to do than i thought.
why pay 10 15 quid on ebay for a scrap board when.i.can now fix for a few quid?
这个答案有帮助吗?
well the person doesn't live near you most likely. Also how can he trust you.
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 51
总计 1,859
