The battery cover is not opening
The battery and sd card cover will not open. It is stuck closed. Can you please advise?
thanks!
@geefamily , GeeFamily, The link below shows how to open battery door. If quite stuck, use a heat gun/hairdryer to heat up around the battery compartment door latch area(carefully heat, not excessive) and then try opening may have to pry a little while sliding/pushing the buttons to open position. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 19
总计 2,545
