跳转到主内容
"The worlds smallest 15.6-inch laptop packs powerhouse performance and a stunning InfinityEdge display all in Dell's most powerful XPS laptop."
Can I add an HDD 2.5 or SSD?
Hello,
I am looking to buy an XPS 15 (9560), but I would need more memory than 512Gb.
Could I add an internal HDD?
Regards
Ricardo
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
you are asking two questions. or you may be confused on parts. first memory is not the same as a hard drive. so are there two questions or just one?
完成的
添加一条评论
3个答案
最有帮助的答案
Ricardo, it looks as if you can add a 2.5" HDD or SSD. The factory SSDs are in a M.2 or mSATA slot, leaving the HDD bay open for upgrade. You may want to consider a Seagate firecudas SSHD for not much more than the price of a regular HDD.
Hope this helps!
这个答案有帮助吗?
得分 4
2条评论:
Here's a guide for doing it:
https://www.parts-people.com/blog/2016/0...
完成的
This is only possible on the version with the smaller battery. The version with the 97Wh battery has no room for a 2.5" drive.
Source: I own both version
完成的
添加一条评论
yes you can up to 1TB
这个答案有帮助吗?
得分 0
1条评论:
I would like to know where you got this information.
完成的
添加一条评论
Yes you can if you have an FHD model. Consider that you'll need an adapter. You can easily find it online
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ricardo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 11
总计 8,769
