跳转到主内容
加入维修社区 - 创建账户
除了 Tahoe Limited 版本外,该车型在 2000 年款进行了重新设计,采用了全新的 GMT800 平台,该平台仍与全尺寸皮卡和 SUV 共享。
My ABS light and TCS light are always on and engaged
My ABS and Traction Control light are always on, how can I fix this and are they absolutely essential or can I just turn them off. It will still pass NY state inspection with them on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
@dragonofaz , Matthew, Check all fuses and relays. Could be faulty wheel bearing/bad/loose wires/plug to ABS sensor or could be faulty ABS sensor, ABS pump motor faulty, EBCM faulty, etc. To help diagnose the issue better, have the vehicle scanned for error/diagnostic codes which may pin point the issue. Some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track. See technical service bulletins (TSB) link below and links to a couple forums that discuss your problem.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.ehow.com/list_7635921_problem...
http://www.tahoeyukonforum.com/threads/a...
http://www.tahoeyukonforum.com/threads/h...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Matthew PRicr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 30
All Time: 3,756
