跳转到主内容
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 个问题 查看全部
Low fuel warning stays on
Fuel low warning lit up with 3/4 full tank. I filled the tank, the light stayed on. I removed the sender and disassembled it and cleaned it. I got a little bit of the black crap out of it but nothing that could bridge the contacts at the bottom. I put it back together and the light stay's on. Bummer. The fuel gage seems to be accurate, the 3 wires are good.
Anyone know where I should look next?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
@old_pat ,Pat, link below had similar issue and stated they had to add additional ground to back side of gage cluster. See link below for more info and pic's. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.benzworld.org/forums/r-c107-s...
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Pat Sweeney 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 1,775
