跳转到主内容
加入维修社区 - 创建账户
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
Frozen reboot screen help
When I try to go to factory restore with holding "0" while starting my comp it freezes. I can not use any keys to do anything. I can only turn it on and shut it off. How do I get around this to restore factory sets?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Try going into f12 when you start up, and switch the BOOT.
完成的
添加一条评论
1个答案
最有帮助的答案
cock_ram , You may need to start removing ,removable components 1 at a time. Pull out one of your Ram memory sticks/modules, reseat the one and try, same with hard drive, as well as battery. Also, check air vents where the fan draws in cool are from the outside, these get clogged up with dust/lint and will cause your machine to freeze due to overheating(clean,blow out). Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
cock_ram 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 91
