How do I remove the drain plugs on the floor pan of a 2002 Volvo S40
My Volvo S40 has been in a flood and I need to drain the water out through the floor plugs. How do I remove them?
denfun09, If you have access to a shop vac, say your buddy or family member has one would also remove the water for you. The floor plugs normally pried out with slotted screw driver/wedged under lip and pry up. If they have some sealant on them may have to heat up a bit with heat gun/hair drier to ease removal. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 667
