Why is my lawn mower not moving
Why would my Craftsman riding lawn mower quit moving? It is about 8 yrs old and has a hydrostatic automatic transmission. It will not move in forward or reverse. Any help would be appreciated.
@jeff1 ,William, You did not state your model, so I will post some generic suggestions. Check the free wheeling lever at the rear of tractor is not engaged(1st link) and park brake off. Check to see the belt is still on and not broke/stretched and for worn pulley's. Check for hydro-static fluid leak or low fluid. Check clutch to see if it is engaging when you switch on, if not check battery condition as it needs good charged battery 12.4 +Volts to engage clutch normally, also could be bad wire/plug/switch for clutch, Control linkage out of adjustment, Internal pump damage. Check the 2nd link as you may be able to get your manual using your model # for more trouble shooting on your issue and suggestions. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
Where is the hydrostatic fluid plug at?
Also check the key way in the axle when you remove your rear tires there is a key way if its broke the axle will spin but the wheel will not
Tried all the suggestions. Mower moved about 300 feet after putting on new belt, then stopped mowing any direction (again). Got it on a mower lift and noticed driver side (left) rear wheel was wobbly. Left axle had cracked at point where square lock pin thingy groove stopped on axle. New transmission ~400.00 from sears….
这个答案有帮助吗?
@lpfaff1 Thank you very much. Your post helped me solve my problem with a “new to me” mower.
Why my 5 speed mower will not move in any gear & I hear clanking noise from gear box or transmission
这个答案有帮助吗?
Help me someone my lawnmower will not come out of gear and it doesn't have a bypass lever
这个答案有帮助吗?
They all have bypass levers. It just might be in a different location
过去 24 小时: 47
过去 7 天: 353
过去 30 天: 1,596
总计 71,285
8条评论
have you checked the lever is connected to the trans
由 Cameron 完成的
I have a 5 speed mower will not move in any gear : but I hear clanking noise from transmission what is the problem
由 Sammie Daniel 完成的
@cam2363 yes lever is moving in to gear butmower will not move belts are tight I raise back tires off ground both are turning but once I put mower in first gear no movement
由 Sammie Daniel 完成的
may be the belt that is under the battery I'm replacing mine
由 heardj71 完成的
I have replaced belt. Mower moves very slow foward sometimes not at all .Will still move in reverse
由 gnfturbo87 完成的
显示更多的3条评论
