跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Digitizer only responds when metal frame is being held in the hand
I have an iPhone 5s I did a screen replacement on after it was dropped and cracked, after replacing the screen/lcd the customer has returned it saying the screen doesnt respond when he has it in his otterbox , So we took it out of the case and it worked great, set it down on the desk, nothing. I tried multiple screens and replacing charging port and still nothing. This device literally only works when it is "grounded" in your hand. I've taped up all contact points and tried without the heatshield/backplate and still nothing.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
9条评论:
Well, it is a grounding issue, how to fix, i have no clue
完成的
Yes, we know its a ground / short issue.
完成的
Does the screen work if you remove the LCD bracket?
Maybe try the motherboard and screen in a different housing.
完成的
I'll give that a shot
完成的
I'm thinkin pressure
完成的
显示更多的4条评论
添加一条评论
1个答案
Is it possible hat 5he frame is bent?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Experimac 314 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 129
