Digitizer only responds when metal frame is being held in the hand
I have an iPhone 5s I did a screen replacement on after it was dropped and cracked, after replacing the screen/lcd the customer has returned it saying the screen doesnt respond when he has it in his otterbox , So we took it out of the case and it worked great, set it down on the desk, nothing. I tried multiple screens and replacing charging port and still nothing. This device literally only works when it is "grounded" in your hand. I've taped up all contact points and tried without the heatshield/backplate and still nothing.
Well, it is a grounding issue, how to fix, i have no clue
由 Cameron 完成的
Yes, we know its a ground / short issue.
由 Experimac 314 完成的
Does the screen work if you remove the LCD bracket?
Maybe try the motherboard and screen in a different housing.
由 The iPhone Guy 完成的
I'll give that a shot
由 Experimac 314 完成的
I'm thinkin pressure
由 iMedic 完成的
显示更多的4条评论
