跳转到主内容
Home security system with 24/7 surveillance capabilities released 2015. Indentified by model number NC1102ES
33 个问题 查看全部
Camera was thrown ...how to tell what's wrong with it?
My (I don't know what to call him) has brain cancer. It causes him to have anger issues. He threw the camera into the wall. It literally made a nest cam shape hole. I plug it in and it doesn't power on. The camera is slightly crooked inside the body. I want to take it apart and have looked at the ways to do so but how do I determine what's not working? I could put it all back together but if it doesn't work still where do I go from there?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@erica14 , Erica, I am very sorry that you are having this problem. Probably at best you can take the camera apart and look for broken/loose wires and loose components and try to re attach by soldering if that is what is found to be the issue. It does take considerable skill when solder on a board, to be careful not to damage other components. If not equipped to do this, perhaps have a friend/family member that could help with repair. If not wanting to attempt the repair, have a good local electronics/computer repair shop have a look, diagnose and estimate repair. Below is a disassembly link that may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Nest Cam Motherboard Replacement
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Erica 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 14
总计 347
