跳转到主内容
加入维修社区 - 创建账户
Nest Cam Motherboard Replacement
你所需要的
  1. Nest Cam Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove the four 6 mm screws from the back panel with the JIS 000 screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Motherboard Replacement: 步骤 2 中的图像 1,3 Nest Cam Motherboard Replacement: 步骤 2 中的图像 2,3 Nest Cam Motherboard Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Motherboard Replacement: 步骤 3 中的图像 1,2 Nest Cam Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove the two 4 mm screws with the JIS 000 screwdriver from the center.
    • Disconnect the black Wi-Fi cable from the motherboard with the tweezers.
  4. Nest Cam Motherboard Replacement: 步骤 4 中的图像 1,3 Nest Cam Motherboard Replacement: 步骤 4 中的图像 2,3 Nest Cam Motherboard Replacement: 步骤 4 中的图像 3,3
    • Use a plastic spudger to lift the motherboard slightly up to expose and disconnect the white cable and the yellow/white IR cable with tweezers.
    • Then use the spudger or a finger to lift the motherboard completely up and off.
    • When installing the new motherboard ensure that all wires are reconnected before securing.
结论
5等其他人完成本指南。
Khiry Jones
于02/29/16注册
159 声望
撰写一个指南
团队
USF Tampa, Team 1-1, Leahy Spring 2016 USF Tampa, Team 1-1, Leahy Spring 2016 的会员
USFT-LEAHY-S16S1G1
7 名成员
创作了10篇指南
4指南评论
where can I get a MoBo for my drop cam?
mikelebp1 - 回复 分享
where can i find a motherboard replacement?
Steve - 回复 分享
I have a Nest Outdoor IQ Camera. The Camera is Dead. Would love to Replace the Motherboard. Where can I get one ???
pmwenc@aol.com - 回复 分享
same here, no where to be found online
chantalder - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 18
过去 30 天: 77
总计 25,366
