跳转到主内容
Released June 2005, identified by model number AL1916.
Monitor turns on and off
I read this article Acer AL1916 Troubleshooting
good morning my monitor is powering all right but the moment it comes for a while goes off. It does not blink on and off the monitor is on but the light is deem how can I go about it to make it appear clear and bright?
Thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I had this problem. I opened the display, noted several heinous looking capacitors on the Poewr Supply board, Installed the correct replacements - haven't had a glitch from it in 3 years.
这个答案有帮助吗?
得分 1
1条评论:
[http://www.markdigital.com/wp-content/up...
Btw, just because a capacitor isn't bulging or leaking doesn't always mean it's 'Good'.
Hope this helps. It is very important to replace the removed devices with those of equivalent value, especially capacitance. Slightly higher voltage doesn't general make too much difference, never replace the device with a lower voltage specification otherwise it go boom.
Good Luck!
完成的
添加一条评论
This is most likely an issue with the backlight. Try shining a flashlight on the screen after it goes black, can you still see the display? If so your backlight is going bad and your lcd is fine.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
enockgyesi5 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 923
