跳转到主内容
加入维修社区 - 创建账户
首先 你得要准备一部iPad Air(1rd Gen)只支持Wi-Fi的机型 这里我们指的是A1474机型 它拥有64位的A7双核处理器并拥有16,32,64GB甚至是128GB的内存选择
Which Adhesive To Use With Battery?
Working on a battery replacement for an iPad Air A1474. There is adhesive holding the battery into the bottom tray of the iPad case. I have a few options on-hand for re-adhering it to the case:
3M 4799 rubber adhesive; or
double-sided strip tape
Would either of these be suitable choices?
Thanks in advance!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Kevin Okie, I have heard and read others use 2 sided tape with out issue to hold battery in place, I think that I have even read that it comes preinstalled on some replacement batteries. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
得分 3
2条评论:
Thanks @lpfaff1!
完成的
Kevin Okie, Thanks for replying back, Good luck with your iPad.
完成的
添加一条评论
添加你的答案
Kevin Okie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 484
