跳转到主内容
A modern, mini, edition of the Nintendo Entertainment System, launched on November 2016. Also known as the Nintendo Classic Mini NES in some markets.
Micro-USB power port is broken
The micro-USB power port on my NES classic broke. Is it an easy fix, and where can i get a replacement port?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@wackowax ,Waqas, If port is found to be bad/loose/damaged , this is really not a repair for the inexperienced because the charge port for your device is soldered to the mother board and the heat generated could cause further damage if not very careful. I will post a link to a tear down guide/vid. to get you inside the Nintendo Classic Mini NES to check the charge port and will also post a link(not your device) showing what is involved in repairing a mini USB attached to the board. You can do a search for replacement port or you may have to try visually matching it up(may be standard type). If not wanting to attempt the repair have a couple good local game/computer repair shops have a look and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.theverge.com/2016/11/13/13614...
https://www.youtube.com/watch?v=Ov-HACi9...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Waqas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 31
总计 3,452
