iPhone doesn't restore after DFU mode?
i just put my iphone in DFU mode...but now it doesn't start...well its start buts get stuck on the apple logo....
tip`?
DANIEL bernesdsd, try this: 1) Hold buttons sleep + home untill iPhone turns off; 2) Open iTunes; 3) Hold home button and plug the phone to your computer. The phone will turn on and the iTunes + Arrow + cable screen will appear.; 4) iTunes will recover you phone from unsuccessful recovery process. Let us know if that helped or if we need to find another solution...good luck:)
这个答案有帮助吗?
no..nothing....all i can se is the battery screen:(
Well if you've tried powering off and that didn't work, and you've tried restoring and that didn't work, I have one other idea. When this happened to me, I let the battery run out so it basically dies. Then once you can't turn it on or anything because there is no battery juice left, plug it in to your charger. What does your battery screen show? Just wondering if your battery is totally discharged or not holding a charge. Just a reminder on the different resets: Soft Reset
1. Press and hold Sleep/Wake on the top of the phone until the red slider appears.
2. Drag the slider.
3. Press and hold the Sleep/Wake button until the Apple logo appears.
If a soft reset doesn’t solve your problem, you may have to resort to performing a hard/factory reset.
Hard Reset
Note: These steps will delete the data off the phone, but you can Restore data using your computer.
Press and hold both the Sleep/Wake button and the Home button for about ten seconds. The apple logo will appear and your iPhone 3G S will be reset.
Oh and BTW use your charger and not the USB of your computer...
if idont have a chariger on it, will will be dead,
and if i have it,,,,the battery is not takiging it, need to have power all the time, tryd to charigt from the wall, tok 24h but still no power on the battery
You may just have a bad or dead battery that will not hold a charge any longer. try and replace it and see what happens.
I am having the same problem! If I try and turn it on the apple logo will come up but then disappear.. My iPhone5 will not restore in recovery or DFU mode and it will not update either?? I have been to the apple the store but they have told me I will need to pay £199 to fix it!! Surely there is a way of fixing it! Help!
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 32
总计 14,788
2条评论
Is this phone jailbroken? What happened before this? Why were you in DFU? Any recent updates? Give us a little bit more info, that may make it easier to isolate the problem. Thanks.
由 oldturkey03 完成的
hello and thank you for your reply.
I recently received it, when previous owner has drop it, if I plug it into the computer, I see that it gets power, and Appel logan comes up ... try to DFU mode, which just gets it started to think, but then stops.
I do not know if they are jailbreak, download a program that would check if they were, but the computer can not because it is stuck in DFU mode
由 DANIEL bernesdsd 完成的
