跳转到主内容
The Plantronics CS50 Headset is a wireless digital headset system manufactured and marketed by Plantronics, Inc.
7 个问题 查看全部
customer cannot hear me although I can hear him.
How to fix the problem? I just received this device by mail, and plugged it to my office phone. When I tried it the I was clearly hearing the client, but the client couldn't hear anything. What's the solution?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@jhallak01 ,Jack, If you have installed/setup as per your manual you may want to try the recommended reset procedure below and if still no go return for replacement/refund.
Press in and hold the mute control (A) and the talk button (B) until the talk indicator light (C) on the headset starts blinking rapidly. Release both buttons.
Press and hold the talk button (B) again. Wait for the talk indicator light to stop blinking, then release the button.
Disconnect the CS50-USB/CS60-USB from your computer's USB port.
If you are also using an AC power supply, disconnect it from the bottom of the base.
Wait 5 seconds, then reconnect the AC power supply and USB cable. The system reset is complete.
Test the headset to ensure it works properly.
Find below a link to CS50 Knowledge base/trouble shooting/manual. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.plantronics.com/us/support/pr...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jack Hallak 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 70
总计 3,739
