跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
Why won't my computer charge from any charger?
My MacBook Pro (OptiBay'd but besides that mint condition) has periods where it will not charge. I have tried using other chargers and other outlets and it just does not charge at all. The MagSafe adapter light stays off too, and jiggling the cable around does not help. Then, eventually after seconds or many hours, it works again. This started off only happening occasionally but now has been happening for ~8 hour periods with only a few minutes break.
Other symptom is that I keep having random shutdowns where when my computer boots up again, my clock is reset back to 2000 and my Airport needs a password again. I have tried resetting the SMC/PRAM (dunno if that worked though).
Please help! What do I replace or do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
Was it dropped? Water damaged? If no, and you are able to put it in factory defAults, just take it to apple store. They should deal with it...
这个答案有帮助吗?
得分 2
1条评论:
+ agreed - take it in and have the warranty work done. Sounds like the magsafe port has gone bad. You probably reset the clock when you zapped the PRAM and have not signed on to the internet.
完成的
添加一条评论
添加你的答案
CStigler 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,443
