跳转到主内容
问题已关闭
How to play iTunes Movies on 4K/1080P TV?
How to play iTunes Movies on 4K/1080P TV? I found that online TunesKit can remove drm from iTunes videos. Is this right and is there any other ways besides removing drm? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
It is important to note that while recording a macro, It will record almost every movement you make. So if you make a mistake in your sequence, p. Eg For example, if you click a button that you did not want to click, the Software records it. The solution is to re-record the entire sequence or change the VBA code yourself. So when you record something, a Macro Recorder is better to record something that you are very familiar with. The more smoothly you record a sequence, the more efficiently the macro will playback. An independent recorder for large-scale software allows a user to “record” mouse and console capabilities to playback later “playback”.
https://crack11.com/macro-recorder-crack...
完成的
添加一条评论
7个答案
最有帮助的答案
I use my Apple TV, and turn on AirPlay.
这个答案有帮助吗?
得分 4
1条评论:
I have a Mac mini as my media server and feed my TV directly (HDMI connected) or in case of my bed room via an Apple TV unit.
Rumor has it Apple will be coming out with a 4K Apple TV this fall. Some content now has 4K as well as HDR listed! New tvOS 11 Beta References 'J105a,' Code Name for Upcoming Apple TV with 4K Support
One of the problems with 4K content is if it was not shot with a 4K rig originally (last few years) it's just converted content so it's muddy Vs crisp.
完成的
添加一条评论
As we all know, iTunes movies or tv shows are all DRM encrypted. We are not allowed to play the iTunes M4V videos with any other Non-Apple devices including 4K/1080P TV you mentioned if you don't have Apple TV. But it seems TunesKit iTunes DRM Removal toolis really a good choice to help us get rid of the DRM protection and enjoy the iTunes medias freely everywhere. I will take it for a try later as well.
这个答案有帮助吗?
得分 1
2条评论:
I love this advice from TunesKit:
When I try to install the TunesKit for Windows, my anti-virus program detected that it contains virus. What's wrong?
Please just ignore the warning. TunesKit for Windows is a newly released application. We haven't applied the Code Signing Certificates from Microsoft yet. That's why we get the warning. But we are sure the program won't make any damage to your computer.
http://www.tuneskit.com/faq.html
完成的
Also this advice was found:
TunesKit for Mac trojan virus removal - Download Notice
Using TunesKit for Mac Free Download crack, warez, password, serial numbers, torrent, keygen, registration codes, key generators is illegal and your business could subject you to lawsuits and leave your operating systems without patches. We do not host any torrent files or links of TunesKit for Mac on rapidshare.com, depositfiles.com, megaupload.com etc. All TunesKit for Mac download links are direct TunesKit for Mac full download from publisher site or their selected mirrors.
Avoid: trojan virus removal oem software, old version, warez, serial, torrent, TunesKit for Mac keygen, crack.
Consider: TunesKit for Mac full version, trojan virus removal full download, premium download, licensed copy.
http://www.bestsoftware4download.com/sof...
完成的
添加一条评论
The easiest way is to use Apple TV to airplay the iTunes movies on your HD TV. If you don't have Apple TV, then you'll have to use TunesKit or other DRM removal tools to remove the DRM firstly. For some other great iTunes movie converters, you can have a test with DRmare M4V Converter, it's a lossless solution that can convert your HD iTunes movies without re-encoding. You can refer to this guide to see how to play iTunes movies on smart TV with DRmare: http://www.drmare.com/drm-m4v-to-tv/play....
这个答案有帮助吗?
得分 0
添加一条评论
There are two ways for you to do this.
First method is to buy an Apple TV, which can help you stream iTunes protected iTunes movies to 4K/1080p TV, which may cost around $199.
The second way is to use the third-party software, like your mentioned tool. But as for me, I usually like to using DRmare M4V Converter for Mac, which is about $44.95. Which one to choose depends on your taste.
这个答案有帮助吗?
得分 0
添加一条评论
iTunes movies are copy protected. If your TV isn't manufactured by Apple or your Apple TV isn't authorized by the account used to purchase the movies, you will fail to play iTunes movies on the TV directly.
Yes, the easiest way is to convert iTunes movies to DRM-free MP4 or other compatible format. The iTunes DRM tool I use is named WinX MediaTrans. Powerful and easy.
But be warned: decode iTunes movies when you own them, and DON'T distribute them to others.
这个答案有帮助吗?
得分 0
添加一条评论
View movie in TV is really a good way to enjoy the movie itself. However, you cannot play movies purchased from iTunes Store on a non-Apple device or an Apple product without the specific account signed in. Because the iTunes movies are protected by Fairplay DRM restriction. You have to kill the DRM with itunes movie DRM software and then the videos can be able to show on other devices.
这个答案有帮助吗?
得分 0
添加一条评论
Depending on what kind of TV you have, I think this issue can be solved by AppleTV. But if you just want to use other files, then I think Waltr2 can help you with this, I use it to transfer music from my PC to my Iphone, it is possible to get it with movies.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 581
