跳转到主内容
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
62 个问题 查看全部
Repair damage- help identify part needed
Have an iPad mini retina att model, while removing the digitizer for a repair a cable going to the cell antena area was severed, can someone help me identify the part needed as well as a reputable source ? See link for image https://drive.google.com/open?id=0B8JUkQ...
Update (04/12/2017)
Sorry about that, tried to post from a mobile and was unable to add a photo here is the photo, thanks for the help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Nicholas, you'll have to clear your link "You need permission" if you want anyone to look at it. You should consider posting your images with your question by using this guide 在已经存在的问题里加入图片
完成的
Repost you picture using something different so we can give your a proper answer. Thanks
完成的
添加一条评论
1个答案
已选择的解决方案
That is the upper right antenna. You can find it here.
Follow this guide(the antenna is specifically addressed on steps 71-73)
iPad mini & mini 2 Right Cellular Antenna图片
产品
$9.99
这个答案有帮助吗?
得分 3
1条评论:
Thanks for the quick answer and part source !
完成的
添加一条评论
添加你的答案
Nicholas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 71
