跳转到主内容
道奇汽车的修理和支持指南。
How do you pushup on the tab to remove the assembly?
I have a 2003 dodge 2500. The key will not turn the ignition. To remove the lock barrel assembly, you must turn the key on so that you can press up on a tab inside. If you can't get the key to turn on, how do you pushup on the tab to remove the assembly?. The truck is sitting inoperable in the driveway now and I can't take it to a locksmith even if I could afford it. Any Ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@bigbart ,M. Williamson, The locksmith will come to you if needed and may save you a lot of time and aggravation. Tumblers will be stuck probably, you can try hitting the key sharply with a mallet on the end while key is installed in ignition, as in video links below to get tumblers to drop and enable you to turn the key. Check links below.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=oFf8xVdA...
https://www.youtube.com/watch?v=pxJE9rDZ...
https://www.youtube.com/watch?v=4PcBuOn7...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
M. Williamson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 48
