Sounds buttons up works but not down.
The volume button only works for the up button. but not the down.
I do not see any replacement part for this or any kind of repair mentioned anywhere.
Hope you can help.
Stephen, The 1st link is a disassembly guide which will get you inside the Tab to check the volume button from the inside to see if it is sticking/dirty, can be repaired or you may have to replace the Power/volume button flex shown in 2nd and 3rd link. Always verify part correct for your device before placing order. You can also do a search for better pricing perhaps using full model#. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Samsung Galaxy Tab 3 8.0 Display Assembly - Touch screen & LCD Display Replacement
http://www.ebay.ca/itm/OEM-SAMSUNG-GALAX...
[关联产品丢失或禁用: IF249-030]
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 60
