跳转到主内容
加入维修社区 - 创建账户
Repair documentation and service information for Hisense televisions.
Replacement Screen / Panel for 55H7B TV
I had a CD tower fall on my screen, no idea how as no one was in the room and it wasn't affected by prior earthquakes, effectively killing the TV. I am needing to replace the screen and have already tried through Hisense support without avail.
Any help would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
It might be cheaper to get a new tv as displays for tv's can be very expensive and at that point, its almost the cost of a new tv, plus you have to take apart the tv and not damage anything. So best suggestion is to get a new TV.
这个答案有帮助吗?
得分 0
4条评论:
Understood, but I want to check into the option and determine for myself.
完成的
I cant seem to find one, like i said they are hard to find and if you can, they are expensive
完成的
That's been my issue.
完成的
Well the best option is to just get a new tv. Displays like i said are near impossible to find and if you can by some miracle, they are expensive. The best bet is to open the tv, and get the model number of the screen its self, and then search for that, its your best option
完成的
添加一条评论
Hisense does not offer replacement screens nor do they source it out to anyone, as I found out by contacting them directly.
这个答案有帮助吗?
得分 0
1条评论:
@tvpoor that is correct :) The only way to replace the screen is by trying to find a panel from a otherwise bad TV. Try a search based on the model of the panel vs. the TV. On the back of the panel should be a label that identifies the panel. Use that number to search for a replacement.
完成的
添加一条评论
添加你的答案
Ted 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 698
