跳转到主内容
Protecting your credit cards from scanning
I know that a metal shield is used in commmercially produced wallets to stop people from using scanning devices to capture credit information from within ones wallet. Can you make a shield by using metal duct tape? Is this metal component thick enough to prevent these scanners from working?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
That would probably work. Personally I would ask my banker, as a lot of the will give you protector sleeves now.
Thin sheets of lead will also do the job. But may result in your employer telling you to get the lead out.
这个答案有帮助吗?
得分 2
添加一条评论
First off, if you are concerned about someone stealing your card info, you shouldn't have a RFID card. Reguardless the prevention of data theft is best practiced by keeping yor card safe. Secondly, to answer your question, the Duct Tape is not thick enough to prevent theft. The thin metalic layer is simply jsut not enough.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jim Goad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 116
