跳转到主内容
The second generation of the Mazda 3, also known as the Mazda3 and Mazda Axela, sedan and hatchback series by Mazda.
10 个问题 查看全部
Revs too high after service
After taking the car for a second service to reduce the revs I still find them higher than when I bought it. The mechanic said all he did was reset the computer. Is there a way I can change the computer settings or how would I go about changing the revs?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
countparas, You can not change the cars computer settings with out special scanner/software/knowledge as normally found at a dealership or well equipped shop.
Ask the dealer ship/shop to show you the cars idle speed specifications cold/warm(operating temp.), if idle speed is in the parameters should probably not adjust further. If not in parameters they should correct the issue. Whether by adjustment/faulty sensor, vacuum leak,throttle body sticking/dirty or having to change program in computer. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
得分 4
添加一条评论
Your mechanic needs to set the rev limiter on the computer.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
countparas 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 16
总计 1,144
