跳转到主内容
衣物干衣机维修和支持指南。
Auto lock is on won't start
Auto lock is on won't start Kenmore Elite HE4 Dryer
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Light stays on tried holding button and also unplugged for several minutes...model 110.85876400 serial MS1805632
完成的
添加一条评论
1个答案
已选择的解决方案
@burza you are not giving us a lot to work with. Try unplugging the dryer for five minutes to allow it to reset. If that does not work hold the "Drain/Spin" buttonAND the main "Start (Press & Hold)" button at the same time for 3 seconds. Some models you will have to hold the "Auto Dry Level" button for 3 seconds or longer until the "Control Locked" light goes off. If the control will not unlock, the failure is likely the console assembly which will likely need to be replaced. It will help if you can give us your complete model number.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Mary 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 432
