跳转到主内容
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
156 个问题 查看全部
Battery cover wont get stuck, it pops out!
What i can do if the back cover broke?!? They are still saying me its the screw that needs to be bigger or larger!!! I need help for this, quick! D:
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
1. Screwing the battery cover attached to the cover still pops out.
2. They are STILL saying me is the screw!
3. They wont understand. :'(
完成的
添加一条评论
2个答案
已选择的解决方案
Santi12008 , If the back or the battery door are broken where it hinges then you may have to replace one or both pieces depending what is broken. I will post a link below to show how to disassemble back/battery door if needed to aide in replacement and a couple links to possible parts which you can also do a search for.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Nintendo Game Boy Advance SP Back Cover Replacement
http://nintendorepairhut.com/repairsuppl...
http://www.ebay.com/sch/i.html?_from=R40...
这个答案有帮助吗?
得分 2
2条评论:
They wont let me do this.
完成的
Santi12008, Sorry, maybe just use a piece of tape for now then to hold battery door in place. Good luck.
完成的
添加一条评论
There is a tiny square nut under the plastic where the battery cover screws in (2mm x 2mm roughly) to accept the screw, and is prone to falling out. If it has, there’s nothing for the screw to bite into, so it will spin but never catch. Hope this helps.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Santi12008 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 25
总计 1,931
